You can look over the Shading Surfaces section of the Input/Output Reference for more info, but to give short answers to your questions:
NOTE: This object DOES NOT interact with the FenestrationSurface:Detailed object to model complex windows. You can define your window using individual glazing and gas material layers in a normal Construction object, model simple windows, or use EMS variables to control shades if you must keep the complex windows.
NOTE: The shading control will be applied to ALL windows with the construction you enter. If you only want want to implement shading control on specific windows, or look at different shading control strategies (setpoints, schedules, blind placement, etc.) across multiple windows in the same simulation, you will need to create multiple window constructions in your model.
