I did find one way to still edit compact schedules in OpenStudio 1.10.0 without having to use the SDK. In the OpenStudio application if you are using a compact schedule within GridView you can select that schedule in the main body of the GridView, and the fields to edit it will be exposed in the inspector. This is demonstrated in the screenshot below.
