I will show you a comment that still lingers in the code today.
// CoolTools counterflow model does not work properly. The empirical model seems flawed
// since the tower operates in the free convection regime on the design day.
I recall when this model was implemented. It was nover determined if the implementation was incorrect or if the original model had flaws. I could probably track down the coefficients, but they would do no good since the simulation would result in warnings and errors.
I recall when this model was implemented. It was nover never determined if the implementation was incorrect or if the original model had flaws. I could probably track down the coefficients, but they would do no good since the simulation would result in warnings and errors.
today.
day. I recall when this model was implemented. It was never determined if the implementation was incorrect or if the original model had flaws. I could probably track down the coefficients, but they would do no good since the simulation would result in warnings and errors.
| 4 | No.4 Revision |
today.
| 5 | No.5 Revision |
