The only suggestion I can offer at this point is to generally review the weather file for anomalies. For example, a scatter plot of the DBT for Chicago looks like this. Look at weather files close to the location of this weather file and compare each weather parameter to see if you can isolate the problem.
The only suggestion I can offer at this point is to generally review the weather file for anomalies. For example, a scatter plot of the DBT for Chicago looks like this. Look at weather files close to the location of this your weather file and compare each weather parameter to see if you can isolate the problem.
