The ability to create and edit many objects in the plugin inspector was removed in version 1.10.0 with this commit in order to fix this issue with those objects being created without required default values, causing the application to crash when it tries to translate the osm to idf. I believe most of them can still be created/edited in the application, or using the SDK.
