Someone has asked a similar question HERE. You would need to connect chiller heat recovery stream to storage tank, then have the storage tank serve as HW supply to campus hot water loop. You will likely need to use a Fluid to Fluid HX object to have the chiller heat recovery water provide heat to the campus hot water loop. Reference the schematic below.
