Adding reheat coils to an air terminal is one of the processes that IS NOT "drag and drop" in OpenStudio. You'll need to:
OS:Coil:Heating:Water object, and make sure the name matches the heating coil you created in your hot water loop.That should set you up to have hot water reheat in your terminals. If you want to connect central heating coils in AHUs to your hot water loop, you should see node icons above and below the coil image. This indicates that the coil is connected to another loop in your model. Also, central coils that are connected to two loops are visible in the "My Model" drop down list for drag-and-drop capability.
It sounds like you're on the right track, but I would double-check these:
