The non-convex warning will only apply to certain Solar Distribution choices in the Building object like you said. The warnings only have an effect when FullInteriorAndExterior or FullInteriorAndExteriorWithReflections are chosen. These choices calculate the amount of beam radiation that falls on each surface in the zone instead of just assuming all of the beam radiation falls on the floor.
The non-convex warning will only apply to certain Solar Distribution choices in the Building object like you said. The warnings only have an effect when FullInteriorAndExterior or FullInteriorAndExteriorWithReflections are is chosen. These choices calculate the amount of beam radiation that falls on each surface in the zone instead of just assuming all of the beam radiation falls on the floor.
