Adding Output:EnergyManagementSystem in the input file generates .edd file which lists all the Actuator available and has other useful information for the EMS. There are plenty examples available in the E+ example files. Basically, following need to be added to generate .edd file.
Output:EnergyManagementSystem,
Verbose, !- Actuator Availability Dictionary Reporting
Verbose, !- Internal Variable Availability Dictionary Reporting
Verbose; !- EMS Runtime Language Debug Output Level
Per the documentation The following actuators are available with the control type called “Schedule Value”: Schedule:Year, Schedule:Compact, Schedule:File, and Schedule:Constant.
