Looks like the issue is an apostrophe in the design day object names. MONTREAL INT'L ANN CLG .4% CONDNS DB=>MWB
This is already documented in this issue. It isn't clear if the fix will be in OpenStudio or EnergyPlus.
The good news is that for OpenStudio 1.10 (due out at the end of the month) each section of the standard report is isolated. A ruby error (e.g. caused by bad sql query or bad model api, etc.) will only result in that section being skipped vs. the entire measure failing.
For now you can edit the design day objets in the GUI to remove the apostrophe.
This is already documented in this issue. for thermal zone names, but seems to affect other objects as well. It isn't clear if the fix will be in OpenStudio or EnergyPlus.
