The message 'DL is deprecated, please use Fiddle' is a result of requiring Win32API in Ruby 2.0, it is a benign warning and out of our control to fix it. The actual error is in the backtrace where it says require': cannot load such file
. As mentioned in this post the eQuest converter measure is a work in progress and that is likely the reason for this error.
