Hi,
I can help you with this problem. First of all can you tell me what version of EnergyPlus did you use? I would also like to see window model that you have created by using WINDOW 7 and what weather file you have used in you simulation?
Hi,
I would also like to see window model that you have created by using WINDOW 7 and what which weather file you have used in you simulation?
Thanks, Simon
Hi,
I can help you with this problem. First of all can you tell me what version of EnergyPlus did you use? I would also like to see window model that you have created by using WINDOW 7 and which weather file you have used in you simulation?
Thanks, Simon
EDIT: Got your files. Will take a look and let you know what the problem is.
| 4 | No.4 Revision |
Hi,
Thanks, Simon
EDIT: Got UPDATE:
Have you tried to do calculations in WINDOW 7 for this system?
Seems that you are missing data for back transmittance and reflectance (shading device). Is it safe to assume that your files. Will take a look shading device is symmetrical? So if it is then you can just copy/paste yours front measured data into back transmittance (and reflectance) and let you know what then perform the problem is.simulation. Of course, edit data in WINDOW 7 and then generate IDF in WINDOW 7.
