Thanks you for asking this question. You are correct, you do not want to model all of the floors; it would take long to model and a ong time to run. The thermal zone multiplier is exposed in the thermal zone tab of OpenStudio 1.5. It is also in earlier versions of OpenStudio but is a little more hidden. If you are using pre-1.5 version I can provide specific instructions.
