The file seems to be corrupted. For example line 1970 has too many entries and starts with a date that is out of sequence. Line 22693 also has too many entries.
I'd take another look at how you generated the file, or at the source data, as it's obviously not working quite as you expected.
click to hide/show revision 2
No.2 Revision
Edited to add
A quick way to find this sort of problem is to open the EPW in Excel, do Data > Text to Columns on the time series part of the data, then Ctrl-down to find any discontinuities - either gaps within the expected data area or extra values beyond it.
