Yes, you can export the model to the .idf, but there is one way more easy, fast and that allows you to change the model direct in OS.
Use the measure zone_report available in BCL. It can be use direct in OpenStudio and will activate the report ZoneComponentLoadSummary.
https://bcl.nrel.gov/node/82313
