|  1 |    initial version    |
That sounds correct, are you hitting run errors when you do this?
    |  2 |    No.2 Revision    |
That sounds correct, are you hitting run errors when you do this?this? I made the loop below by dropping in one of the template systems that use a cold water loop. I deleted the chiller and then dragged the Distict Cooling to the "Drag From Library" dropzone.
