Hi all, First of all, thanks to OS team for developing such a good and complete tool for energy and light modeling! I join you an *.osm file (just change the extension). I just tried to run a radiance simulation, with the dedicated script, and I think it’s not working.
I let the default folder installation.
The daylight sensor illuminance is equal to 0, so i don’t have the mean illuminance map, nor illuminance map, etc. Am I doing something wrong?
I’m working with OS 1.9.1 and have win 7 64 bits.
Thanks for your help!
Regards,
Mathieu
Running radiance in directory: 'C:/Users/mathieu/AppData/Local/Temp/OpenStudio.yV5892/resources/run/1-UserScript-0/radiance' Executing: epw2wea "C:\Users\mathieu\AppData\Local\Temp\OpenStudio.yV5892\resources\run\1-UserScript-0\in\files\ECU_Quito.840710_IWEC.epw" wx\in.wea 2015-11-19 17:50:13 UTC: passing 101 calculation points to Radiance 2015-11-19 17:50:13 UTC: computing daylight coefficient matrices Executing: oconv materials\materials.rad model.rad > model_dc.oct 2015-11-19 17:50:13 UTC: oconv "materials/materials.rad" "materials/materials_WG0.rad" model.rad "skies/dc_sky.rad" > model_WG0.oct Executing: oconv "materials\materials.rad" "materials\materials_WG0.rad" model.rad "skies\dc_sky.rad" > model_WG0.oct 2015-11-19 17:50:13 UTC: computing daylight/view matrix for static window group (WG0)... 2015-11-19 17:50:13 UTC: type "numeric/merged_space.map" | rcontrib -ab 6 -ad 4050 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -o "output/dc/WG0.vmx" -m skyglow model_WG0.oct Executing: type "numeric\merged_space.map" | rcontrib -ab 6 -ad 4050 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -o "output\dc\WG0.vmx" -m skyglow model_WG0.oct 2015-11-19 17:50:15 UTC: computing view matri(ces) for controlled windows Executing: type "materials\materials_vmx.rad" > receivers_vmx.rad Executing: oconv materials\materials.rad scene\Space_101.rad > model_vmx.oct Executing: rfluxmtx -ab 6 -ad 4050 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -n 4 -ds .15 -faa -y 101 -I -v - receivers_vmx.rad -i model_vmx.oct < numeric\merged_space.map Executing: oconv "materials\materials.rad" model.rad "skies\dc_sky.rad" > model_wc.oct 2015-11-19 17:50:15 UTC: computing DCs for window control points Executing: type "numeric\window_controls.map" | rcontrib -ab 2 -ad 512 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -o "output\dc\window_controls.vmx" -m skyglow model_wc.oct 2015-11-19 17:50:15 UTC: done (daylight coefficient matrices). 2015-11-19 17:50:15 UTC: Calculating annual daylight values for all window groups and shade states Executing: gendaymtx -m 1 "wx\in.wea" > annual-sky.mtx Executing: dctimestep "C:\Users\mathieu\AppData\Local\Temp\OpenStudio.yV5892\resources\run\1-UserScript-0\radiance\output\dc\WG0.vmx" annual-sky.mtx | rmtxop -fa -c 47.4 120 11.6 - > "C:\Users\mathieu\AppData\Local\Temp\OpenStudio.yV5892\resources\run\1-UserScript-0\radiance\output\ts\WG0.ill" Executing: dctimestep output\dc\window_controls.vmx annual-sky.mtx | rmtxop -fa -c 47.4 120 11.6 - | getinfo - > output\ts\window_controls.ill 2015-11-19 17:50:24 UTC: Merging results: Executing: rmtxop -fa output\ts\WG0.ill -t | getinfo - > "output\ts\merged_space.ill" 2015-11-19 17:50:25 UTC: Executing simulation 2015-11-19 17:50:25 UTC: writing output WARN: an error has occurred; no results for space 'Space_101'.
