Yes OpenStudio is compatible with SketchUp 2016. SketchUp 2016 will be the default install location for the OpenStudio SketchUp Plug-in starting in OpenStudio 1.10.0 (December release). In the meantime, you can install OpenStudio 1.9.0 with SketchUp 2016 by following the instructions here, just replace SketchUp 2015 with 2016 and use the version of OpenStudio you have.
SketchUp 2016 introduced extension signing for security reasons. OpenStudio versions below 1.10.0 will not have security certificates and will require you to manually approve loading the OpenStudio plug-in, see this article for more information. OpenStudio 1.10.0 and above will be signed and will not require manual approval.
