No this is not possible at this point, but it is a great User Voice suggestion. Thanks to @Eric Ringold for finding the spot, you can see in the source code that it only accepts the variable name or "*".
That said, I think adding a true wildcard or regular expression looks possible (on the surface). So add this as a suggestion on User Voice.
