Ashok,
You're a little out of luck as far as getting proper sources for this. I've looked into the DOE-2 Engineers Manual version 2.1A (here) and there is nothing about photovoltaic generators. I supposed it was added later.
Though, looking at eQuest and the help files, you can already understand what is going on. I've looked at the source code of DOE22 as well, especially in PLT.LIS that is in the folder SRC48r, and you could do the same.
Anyway, in DOE2 you'll enter the characteristics of your PV Modules, especially the performance data. That's basically going to play on the efficiency of your modules. Then, you'll create your generator. A number of parameters come into play in the calculation routine. The array tilt for example is used to determine the electric capacity (direct and diffuse solar, angle of incidence, air mass, and ambient temperature are the parameters for that).
As far as modeling the "other losses", what you really want to be looking at is the EIR and the EIR-FPLR curves:
ELEC-INPUT-RATIO
specifies the ratio of direct-current input power to alternating-current output power. This number is the inverse of the full-load efficiency, and as such is always greater than 1.0.
EIR-FPLR
accepts the U-name of a curve that modifies the nominal electric input ratio as a function of the hourly part load ratio. This use of this curve is identical to part-load curves documented elsewhere.
I guess you might also play with the auxiliary power, but I think the main goal of this was to include say the power used for a sun tracking system.
Choose the ELEC-INPUT-RATIO to include all your regular losses such as wiring losses, potential step up transformer losses, etc. Choose the EIR-FPLR to match your inverter characteristics.
The EIR-FPLR that is included by default in eQuest is called "Inverter EIR-fPLR" and it's easy to see it's coefficients. For your convenience, it's a Quadratic curve (Z = a + bX + cX²) with coefficients (a, b, c) = (0.01677774, 1.03766644, -0.05444432).
Now, this is not what you are used to see. What you are used to see is the efficiency of the inverter. The default eQuest inverter looks like this:
If I assume an ELEC-INPUT-RATIO of 1.075 (= 93% efficient, I'm voluntarily taking a fairly low number in order to be able to see the difference), the Total Efficiency of the system would look like:
I hope this clarifies things.
Ashok,
You're a little out of luck as far as getting proper sources for this. I've looked into the DOE-2 Engineers Manual version 2.1A (here) and there is nothing about photovoltaic generators. I supposed suppose it was added later.later, after 1993.
ELEC-INPUT-RATIO
EIR-FPLR
The EIR-FPLR that is included by default in eQuest is called "Inverter EIR-fPLR" and it's easy to see it's its coefficients. For your convenience, it's a Quadratic curve (Z = a + bX + cX²) with coefficients (a, b, c) = (0.01677774, 1.03766644, -0.05444432).
Ashok,
You're a little out of luck as far as getting proper sources for this. this, at least in terms for something clearly written and directly quotable. I've looked into the DOE-2 Engineers Manual version 2.1A (here) and there is nothing about photovoltaic generators. I suppose it was added later, after 1993.
ELEC-INPUT-RATIO
EIR-FPLR
The EIR-FPLR that is included by default in eQuest is called "Inverter EIR-fPLR" and it's easy to see its coefficients. For your convenience, it's a Quadratic curve (Z = a + bX + cX²) with coefficients (a, b, c) = (0.01677774, 1.03766644, -0.05444432).
