Have you tried clicking the ResultsViewer button just above the results report? ResultsViewer allows you to create time series and flood plots for a variety of variables in your model. If you're looking to create a standard plot that's generated every time then you'll probably want to create a measure or modify an existing measure.
Have you tried clicking the ResultsViewer button just above the results report? ResultsViewer ResultsViewer allows you to create time series and flood plots for a variety of variables in your model. If you're looking to create a standard plot that's generated every time then you'll probably want to create a measure or modify an existing measure.
