1 | initial version |
Try adding an Output:Diagnostics object to DisplayAllWarnings, which will add more detail to the ERR file.
Some other thoughts:
Check the ERR file for more detail about the error(s)
If you're using OpenStudio make sure the model has a weather file (may need to re-select it).
