Make sure you use the newer versions of OpenStudio that work with the ".OSM" file format. Not the legacy OpenStudio Plug-in that works only with ".IDF" files. The current major release is 1.9.0 and is at the top of this page, above the legacy download link.
You can import and export gbXML from the plugin or the stand alone OpenStudio application.
