Hey Annie - here are a couple options:
BTAP eQuest Converter
I haven't used any of these and the last one is the OpenStudio measure Amir mentioned. It's not publicly available, but @macumber can probably send you a copy.
I haven't used any of these and the last one is the OpenStudio measure Amir mentioned. It's not As far as I know it's not publicly available, but @macumber can probably send you a copy.
| 4 | No.4 Revision |
I haven't used any of these and the last one is the OpenStudio measure Amir mentioned. As far as I know it's not publicly available, but @macumber can probably send you a copy.
