This warning is telling you that you haven't referenced the SOLARCOLLECTOR:UNGLAZEDTRANSPIRED in your air system. Typically, it should appear in the outdoor air system.
![]() | 2 | No.2 Revision |
This warning is telling you that you haven't referenced the SOLARCOLLECTOR:UNGLAZEDTRANSPIRED in your air system. Typically, it should appear in the outdoor air system.system. You can see how it's referenced in this example file.
