I think you are looking for eplusoutMeter.csv instead of eplusout.mtr.
To generate the eplusoutMeter.csv based on the eplusout.mtr, you can create a text file (for example: test.txt).
The "test.txt" will have two rows:
path/to/eplusout.mtr
path/to/eplusoutMeter.csv
Run: C:\EnergyPlusV8-3-0\PostProcess\ReadVarsESO.exe test.txt
You will find the eplusoutMeter.csv generated based on the eplusout.mtr.
It will be good for OpenStudio to run this post processing automatically.
You can create an issue on OpenStudio website.
![]() | 2 | No.2 Revision |
To generate the eplusoutMeter.csv based on the eplusout.mtr, you can create a text file in the same folder as the eplusout.mtr (for example: test.txt).
path/to/eplusout.mtr eplusout.mtr
path/to/eplusoutMeter.csveplusoutMeter.csv
![]() | 3 | No.3 Revision |
eplusout.mtr
eplusoutMeter.csv
Open CMD and cd to the result folder and Run: C:\EnergyPlusV8-3-0\PostProcess\ReadVarsESO.exe test.txt
![]() | 4 | No.4 Revision |
eplusout.mtr
eplusoutMeter.csv
You can create an issue on OpenStudio OpenStudio website.
![]() | 5 | No.5 Revision |
eplusout.mtr
eplusoutMeter.csv
You can create an issue request on OpenStudio website.the uservoice site.
![]() | 6 | No.6 Revision |
eplusout.mtr
eplusoutMeter.csv
You can create an request on the uservoice uservoice site.
