1 | initial version |
When the demand is lower than the minimum part load, I believe EnergyPlus will operate the boiler at 20% capacity because it can't operate at lower loads. The boiler does not cycle to meet the lower loads, it just outputs it's minimum. The result is hotter than normal outlet temperatures.
2 | No.2 Revision |
When the demand is lower than the minimum part load, I believe EnergyPlus will operate the boiler at 20% capacity because it can't operate at lower loads. The boiler does not cycle to meet the lower loads, it just outputs it's its minimum. The result is hotter than normal outlet temperatures.
3 | No.3 Revision |
When the demand is lower than the minimum part load, I believe EnergyPlus will operate the boiler at 20% capacity because it can't operate at modulate to lower loads. The boiler does not cycle to meet the lower loads, it just outputs its minimum. The result is hotter than normal outlet temperatures.
