Please have a look at This Document. This will explain how you can open an epw file into excel, from where you can easily find which column represent which variables. You can also look at AuxiliaryPrograms document, which can be found in Documentation folder.
Please have a look at This Document. This will explain how you can open an epw file into excel, from where you can easily find which column represent which variables. variable.
Please have a look at This Document. This will explain how you can open an epw file into excel, from where you can easily find which column represent which variable. represents each weather parameter.
