Make sure you update the version in both the EnergyPlus input file.idf file and the template .ini
Make sure you update the version in both all of the EnergyPlus input file.idf file and files referenced.
For example, in the template .ini you could have two idf files in there:
Simulation { Files { Template { File1 = singleZonePurchAir_template.idf; } Input { File1 = singleZonePurchAir.idf; } Log { File1 = singleZonePurchAir.err; } Output { File1 = singleZonePurchAir.eso; }
In which case you'd need to modify the singleZonePurchAir.idf and the singleZonePurchAir_template.idf.
