click to hide/show revision 1
initial version
There is a section in Getting Started document. Please see Here. I believe there are also other online resources that details zoning process.
click to hide/show revision 2
No.2 Revision
There is a section in Getting Started document. Please see Here. I believe there are also other online resources that details zoning process. process.
Below are some of the zoning aspects that you may consider (thanks to Jim Dirkes)
  • ·Use as few zones as possible to speed simulation time and debugging. DesignBuilder’s “Merge Zones” feature is very helpful for doing this.
  • ·Normally, a zone should not represent each room or VAV box. Combine into one zone all areas which have:
    • · Similar schedule
    • · Similar densities (people, lighting and plug loads)
    • · Use the same temperature and humidity setpoints
    • ·Have the same sun exposure
    • ·Are served by the same HVAC air system
  • ·Note that you may combine rooms that use different thermostats as long as their temperature setpoints are the same.
  • ·Separate HVAC systems (e.g., packaged rooftop units) may be combined if the efficiencies and operating controls are the same.
  • ·Areas on different floors may become part of a single zone if they meet the criteria above
  • ·Perimeter areas (within ~12-15 feet of the exterior wall) are normally treated separately from interior / core areas
    • ·If the perimeter is well insulated and has no windows, it may be combined with interior / core areas
click to hide/show revision 3
No.3 Revision
  • ·Use Use as few zones as possible to speed simulation time and debugging. DesignBuilder’s “Merge Zones” feature is very helpful for doing this.
  • ·Normally, Normally, a zone should not represent each room or VAV box. Combine into one zone all areas which have:
    • ·Have Have the same sun exposure
    • ·Are Are served by the same HVAC air system
  • ·Note Note that you may combine rooms that use different thermostats as long as their temperature setpoints are the same.
  • ·Separate Separate HVAC systems (e.g., packaged rooftop units) may be combined if the efficiencies and operating controls are the same.
  • ·Areas Areas on different floors may become part of a single zone if they meet the criteria above
  • ·Perimeter Perimeter areas (within ~12-15 feet of the exterior wall) are normally treated separately from interior / core areas
    • ·If If the perimeter is well insulated and has no windows, it may be combined with interior / core areas
click to hide/show revision 4
No.4 Revision
  • Use as few zones as possible to speed simulation time and debugging. DesignBuilder’s “Merge Zones” feature is very helpful for doing this.
  • Normally, a zone should not represent each room or VAV box. Combine into one zone all areas which have:
    • Similar schedule
    • Similar densities (people, lighting and plug loads)
    • Use the same temperature and humidity setpoints
    • Have the same sun exposure
    • Are served by the same HVAC air system
  • Note that you may combine rooms that use different thermostats as long as their temperature setpoints are the same.
  • Separate HVAC systems (e.g., packaged rooftop units) may be combined if the efficiencies and operating controls are the same.
  • Areas on different floors may become part of a single zone if they meet the criteria above
  • Perimeter areas (within ~12-15 feet of the exterior wall) are normally treated separately from interior / core areas
    • If the perimeter is well insulated and has no windows, it may be combined with interior / core areas
