As of OpenStudio 1.9.0, both Chiller:Absorption and Chiller:Absorption:Indirect are available both in the application and the OpenStudio SDK. You can add them to a plant loop in the application by dragging the objects from the 'Library' pane on the right of the HVAC Systems tab into your loop.
