click to hide/show revision 1
initial version
Your are not missing anything. Use of those silly constant functions has been mostly deprecated elsewhere in EnergyPlus and replaced with calls to GetSpecificHeatGlycol (where 0% glycol is water). EMS should really be extended to expose that, and also GetDensityGlycol.
Your are not missing anything. Use of those silly constant functions has been mostly deprecated elsewhere in EnergyPlus and replaced with calls to GetSpecificHeatGlycol GetSpecificHeatGlycol (where 0% glycol is water). EMS should really be extended to expose that, and also GetDensityGlycol. GetDensityGlycol.
