I would propose to take front and reverse side surface temperatures [output values] of walls etc. and then calculate the temperatures at each layer in constructions from conductivities of materials. This should be possible using EMS programs and output variables, or other methods of postprocessing (e.g. using spreadsheet calculations on csv output of surface temperatures)
