1 | initial version |
Do you try to figure out the contribution of each components in the heating or cooling energy consumption?
If yes, you can check the "Sensible Heat Gain Summary" in the <filename>Table.html file. It looks like: Capture.PNG
You need to add one of the IDF object to your IDF file.
Output:Table:SummaryReports, AllSummary;
or
Output:Table:SummaryReports, SensibleHeatGainSummary;
