1 | initial version |
For detailed descriptions of HVAC object fields you should check out the EnergyPlus documentation at http://energyplus.net. OpenStudio (for the most part) maintains a 1:1 mapping with HVAC objects so the EnergyPlus documentation will contain the explanations you're looking for.
