Since we switched to an HTML based simulation report in 1.4.0 it hasn't responded to the units setting in the application. For SI results you can view the standard energyplus output from within OpenStudio, or write a custom SI measure.
Unit aware measures (reporting or model) would be a good feature request to add to the OpenStudio User Voice page.
In fact it looks like someone else has requested this, but you can add your vote to the request.
