MyModelName\run\5-EnergyPlus-0 directory. Also, many of the available variables stay the same between different models, so you can look at any old .rdd file you have laying around to copy from and most of the time you'll be fine. Requesting variables that aren't available will at worst throw warnings during the E+ run. | 2 | No.2 Revision |
