EnergyPlus will typically operate the fan to meet the load the system sees (either ventilation, heating, or cooling). The only way to override this behavior and set the flow rate manually is through an EMS Actuator on the "Fan Air Mass Flow Rate".
click to hide/show revision 2
No.2 Revision
You can set the ventilation requirements using the DesignSpecification:OutdoorAir object's Outdoor Air Flow Rate Fraction Schedule Name field.
The only way to override this behavior and set the flow rate manually of the fan directly is through an EMS Actuator on the "Fan Air Mass Flow Rate".
click to hide/show revision 3
No.3 Revision
You Since your DOAS operates only to meet the ventilation requirement, you can set the ventilation requirements using the DesignSpecification:OutdoorAir object's Outdoor Air Flow Rate Fraction Schedule Name field.
The only way to override this behavior and You can also set the flow rate of the fan directly is through using an EMS Actuator on the "Fan Air Mass Flow Rate".
