The Envelope Table of the standard results report in OpenStudio gives the total area by construction. This uses net vs. gross wall area for the calculation. It doesn't list every surface, but does show a surface count. If you need to see each surface use @Annie Marston's suggestion. If you wanted a detailed report on each surface in OpenStudio you could write a measure for that using the surface.netArea method.
The Envelope Table of the standard results report in OpenStudio 1.9 gives the total area by construction. This uses net vs. gross wall area for the calculation. It doesn't list every surface, but does show a surface count. If you need to see each surface use @Annie Marston's suggestion. If you wanted a detailed report on each surface in OpenStudio you could write a measure for that using the surface.netArea method.
The Envelope Table of the standard results report in OpenStudio 1.9 gives the total area by exterior construction. This uses net vs. gross wall area for the calculation. It doesn't list every surface, but does show a surface count. If you need to see each surface use @Annie Marston's suggestion. If you wanted a detailed report on each surface in OpenStudio you could write a measure for that using the surface.netArea method.
