I typically avoid creating loose geometry when drawing exterior doors and windows.
I double-click on the exterior space to select it, and then draw windows on the surfaces...
Double-click to select space:
If you have the space selected when you draw windows on the surfaces, the OS plugin should automatically create the appropriate subsurface without the need to project loose geometry.
