1 | initial version |
a simple recipe is as follows: specify
AirflowNetwork:MultiZone:Zone
AirflowNetwork:MultiZone:Surface
)AirFlowNetwork:Multizone:Component:*
or ...:MultiZone:Surface:Crack
you will need some assumptions or data on air mass flow when opening is closed, discharge coefficients etc.AirflowNetwork:MultiZone:ExternalNode
) for affected facades, roof surfaces,
with associated wind pressure coefficient specsAirflowNetwork:SimulationControl
detailsWith pure natural ventilation, you will not have control over the direction of airflows, in fact there will usually occur flows in both opposite directions. This can be monitored via appropriate output variables.
However, there is the option of using venting controls for zones and openings. As an example, you may find more details here.
