Yes, the IDD can be the same for all projects and EPPy just needs a path to the version corresponding to the IDF(s) you're working with, which can be the default EP directory.
The error you're seeing is normal and a result of the way the current code is written (ref: Issue 49).
To fix it, try starting a new session. Often I'm able to "debug" strange errors in IPython by simply starting fresh.
