You could also you the ZoneVentilation:DesignFlowRate object.
![]() | 2 | No.2 Revision |
You could also you perhaps use the ZoneVentilation:DesignFlowRate object.
![]() | 3 | No.3 Revision |
You could also perhaps use the ZoneVentilation:DesignFlowRate object.object set up correctly.
![]() | 4 | No.4 Revision |
You I am not quite sure if that is what you are asking but you could also use the ZoneVentilation:DesignFlowRate object set up correctly.
