You can also have each measure write its own file and have the other measures read it. For this to work on both PAT( OS-app) and the OS-server, the following directories should work:
json_path = '../OtherMeasureDirectoryName/results.json' #this is the path structure on the server
if File.exist? ems_path
ems_string = File.read(ems_path)
if File.exist? json_path
json = JSON.parse(File.read(json_path))
end
else
json_path2 = Dir.glob('../../**/results.json') #this will parse the directory structure with PAT/OS-app
json_path1 = json_path2[0]
end
end
This will probably change next year once OS-server and OS-App use the same workflow manager, but this is a way off.
