We have done this at NREL using the parametric capabilities of OS-Server and Spreadsheet in combination with the ProtoType Buildings Measure. You can pivot on building type, climate zone and vintage to get every combination if you wish, and then apply any other measures you want to the analysis.
If this is something you want to try, I can post a spreadsheet setup to do this. You would need to follow instructions on the spreadsheet github repo to set everything up first.
