A search for the sketchup and surfaces tags show the links below. I will add that it's important to make sure you draw your model carefully and cleanly - i.e. making sure that there are no stray marks and that adjacent lines/surfaces are in fact touching.
https://unmethours.com/question/666/help-regarding-rendering-and-white-surfaces/
https://unmethours.com/question/909/surface-interaction-and-match-problem/
https://unmethours.com/question/996/corrupt-openstudio-model/
A search for through the sketchup and surfaces tags tagged questions show the links below. I will add that it's important to make sure you draw your model carefully and cleanly - i.e. making sure that there are no stray marks and that adjacent lines/surfaces are in fact touching.
