Sometimes I have this same problem and some surfaces doesn't match because Im using a complex geometry on the model , you could use the Open Studio Inspector Tool (is like a magnificent glass whit a cube inside) to match the surfaces that you need, it could take some time but makes the job :D
Sometimes I have this same problem and some surfaces doesn't match because Im I'm using a some complex geometry on the model , model, you could use the Open Studio Inspector Tool (is like a magnificent glass whit a cube inside) to match the surfaces that you need, it could take some time but makes the job :Ddone :D.
Julian.
