Sorry, there isn't a away to to view IP in ResultsViewer application. It works with native SQL data which is in SI. If you write reporting measures to create plots you can convert to IP. The Zone Report reporting measure uses zomable time series line plots more similar to what you would see in Results Viewer. It can give you an idea of what is possible.
Sorry, there isn't a away to to view IP in ResultsViewer application. It works with native SQL data which is in SI. If you write reporting measures to create plots you can convert to IP. The Zone Report reporting measure uses zomable zoomable time series line plots more similar to what you would see in Results Viewer. It can give you an idea of what is possible.
