I was able to reproduce this even when running EP-Launch as an admin. I believe that the issue is likely due to EP-Launch writing to the executable directory, OpenStudio installs to Program Files which has reduced permissions. I would recommend installing EnergyPlus separately if you want to use EP-Launch, EP-Launch may be removed from the OpenStudio install at some point anyway.
