I've created an IRC channel on freenode (where you already have #ruby and #python for example): here's a direct link to try it out using a web browser: #UnmetHours, or an irc link: irc://irc.freenode.net/unmethours
On people's suggestion, here's a Slack as well: https://unmethours.slack.com/signup.
Apparently Slack is more user friendl, I have to agree IRC is a bit plain and can feel outdated.
We'll see what people start to use more and kill the other.
On people's suggestion, here's a Slack as well: https://unmethours.slack.com/signup.EDIT:
Apparently On people's suggestion, Slack is probably a better fit, seems more user friendl, friendly. IRC is, I have to agree IRC is admit, a bit plain and can feel outdated.
We'll see what people start to use more and kill Join the other.slack here: https://unmethours.slack.com/signup.
EDIT:
On people's suggestion, Slack is probably a better fit, seems more user friendly. IRC is, I admit, a bit plain and outdated.
Join the slack here: https://unmethours.slack.com/signup.
EDIT N°2:
The problem right now is that slack doesn't let anyone join (you have to specify which email domains can join, and I can list them all). Until we work something better, use the following google form to add your email address. One of the slack admins will invite you to join.
<iframe src="https://docs.google.com/forms/d/1suQ-mvKr7Hb99luW07ofa5KFnQbOLP_B_PqzNYK6SMg/viewform?embedded=true" width="760" height="500" frameborder="0" marginheight="0" marginwidth="0">Loading...</iframe> | 4 | No.4 Revision |
EDIT:
EDIT N°2:
| 5 | No.5 Revision |
EDIT:
EDIT N°2:
EDIT 3:
Something better: request an invite by emailing unmethours@gmail.com with the subject [INVITE ME] and you'll get an invoice in the next five minutes.
| 6 | No.6 Revision |
EDIT:
EDIT N°2:
EDIT 3:
Something better: request an invite by emailing unmethours@gmail.com with the subject [INVITE ME] and you'll get an invoice invite in the next five minutes.
| 7 | No.7 Revision |
EDIT:
EDIT N°2:
EDIT 3:
Something better: request an invite by emailing unmethours@gmail.com with the subject [INVITE ME] [SLACK INVITE] and you'll get an invite in the next five minutes.
| 8 | No.8 Revision |
EDIT:
On people's suggestion, Slack is probably a better fit, seems more user friendly. IRC is, I admit, a bit plain and outdated.friendly, more up to date.
Join the We have created an UnmetHours slack here: https://unmethours.slack.com/signup.
EDIT N°2: https://unmethours.slack.com.
The problem right now is that slack Slack doesn't let anyone join (you join, you have to specify which email domains can join, and I can can't list them all). Until we work something better, use the following google form all, and common 'personal' email domains such gmail are forbidden.
@JamieBull created a bot to automatically add your email address. One of the slack admins will invite you to join.Slack.
EDIT 3:
Something better: The only thing you need to do is to request an invite by emailing unmethours@gmail.com with the subject [SLACK INVITE] INVITE] and you'll get an invite in the next five minutes.minutes.
| 9 | No.9 Revision |
On people's suggestion, Slack is a better fit, more user friendly, more up to date.
We have created an UnmetHours slack here: https://unmethours.slack.com.
The problem right now is that Slack doesn't let anyone join, you have to specify which email domains can join, and I can't list them all, and common 'personal' email domains such gmail are forbidden.
@JamieBull @Jamie Bull created a bot to automatically add you to Slack.
The only thing you need to do is to request an invite by emailing unmethours@gmail.com with the subject [SLACK INVITE] and you'll get an invite in the next five minutes.
| 10 | No.10 Revision |
Also, anyone using an email address from one of the following domains doesn't need to be invited specifically: @unmethours.com, @bigladdersoftware.com, @nrel.gov, @altanova-energy.com, @ornl.gov and @lbnl.gov. They're all pre-approved.
| 11 | No.11 Revision |
Also, anyone using an email address from one of the following domains doesn't need to be invited specifically: @unmethours.com, @bigladdersoftware.com, @effibem.com, @nrel.gov, @altanova-energy.com, @ornl.gov @ornl.gov, @lbnl.gov and @lbnl.gov. @bigladdersoftware.com. They're all pre-approved.
Worth noting that you can also get invited by anyone already on the Slack Channel.
